[Mapserver-dev] Generic tiling (for shapefiles and rasters)...
Daniel Morissette
dmorissette at dmsolutions.ca
Wed Mar 10 10:20:04 EST 2004
woodbri at swoodbridge.com wrote:
> On 9 Mar 2004 at 22:49, Steve Lime wrote:
>>A bit more verbose but now you can do filtering within your tiles. For
>>example, you could take a single county out of production. Or you
>>could store multiple years worth of data within the same tile and could
>>specify a particular year at runtime.
> Would achieve the filtering using the FILTERITEM in the tile layer?
Yes, this is my understanding, so in your case you could set FILTER on
the tile index to select only the state you're interested in and you're
running.
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
