[Mapserver-dev] perl-mapscript
Sean Gillies sgillies at frii.com
Wed Mar 17 11:02:01 EST 2004
On Mar 17, 2004, at 8:24 AM, Frank Warmerdam wrote:
> John Beisley - RSG wrote:
>> Hi,
>> I'm not sure if this is the right place to ask this, but I currently
>> have a problem with perl-mapscript (PHP-mapscript not being an
>> option). The problem is that adding "proccessing" directives to a
>> raster layer is not possible currently within perl-mapscript. Is this
>> likely to be included in a nightly build soon, or should I try to
>> implement it myself? I'm not yet sure if I have the knowledge to put
>> this feature in myself, however.
> John,
> I have committed some updates in CVS this morning adding a
> setProcessing()
> method on the layerObj.  The argument is a string which would be the
> same
> sort of string used as an argument for the PROCESSING directive in a
> mapfile.
> I presume this will flow into a nightly build soon. I don't exactly
> know how
> those are managed.
> I also fleshed in the mapscript/doc/mapscript.txt entries for all the
> methods
> I am aware of on the layerObj.  Mostly copied and slightly edited from
> the
> PHP MapScript documentation.
Frank, I took the liberty of adding you to the new bug in Bugzilla.
Thanks for filling out layerObj's methods ... I'd been putting this off
since
it was a pretty big job.  I made just a few changes (hope you don't
mind) to
add hyperlinks in the method prototypes, converted it to HTML and have
updated
the page under
http://users.frii.com/sgillies/projects/mapscript/
Sean
