[Mapserver-dev] Re:WMS Problems...
Frank Warmerdam
warmerdam at pobox.com
Wed Mar 17 11:41:36 EST 2004
Steve Lime wrote:
> This discussion sort of withered on the vine. Issue number 3 is a big
> deal especially with
> WCS. We'll have a need to serve multiband images (8-bits/band) and
> 16-bit single band
> images from the same server. The same TIFF OutputFormat is not going
> work for both of
> those cases. The other issues are import too. Anyone care to resurrect
> or should I just
> file bugs?
Sean Gillies wrote:
> Steve,
> I vote that outputformats be changed so that we can have multiple
> formats using the same driver. Have the format name be the primary
> format identifier instead of the driver.
> Sean
Guys,
Are you sure this doesn't work already? I use multiple outputformat
declarations for the same driver all the same time ... just with different
options and a different name. It seems if we also override the mimetype
they should even be selectable via WMS (or WCS). Is there actually an
action item her or should someone just go ahead and test the capability.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
