[Mapserver-dev] RE: Working PHP Mapscript module produced with SWiG?!
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Fri Mar 19 12:51:07 EST 2004
Hi Paul,
> -----Original Message-----
> From: Paul Ramsey [mailto:pramsey at refractions.net]
> Sent: 18 March 2004 18:08
> To: Mark Cave-Ayland
> Cc: 'mapserver-dev'
> Subject: Re: Working PHP Mapscript module produced with SWiG?!
> Congratulations Mark, I am frankly surprised at how much the
> SWIG PHP4
> support has improved since my last try. I did manage to compile a
> working .so last year, but "working" is a loose use of the
> work. Many of
> the functions did not work, and subobjects were flaky at best.
I've had a look at the generated wrapper script and it looks as if there
is special code to detect whether a class member is an object or not and
to behave accordingly - something to do with PHP being weakly-typed. It
could be that before this was fixed, it was the cause of the problems
you were experiencing....
> Good news!
> Is there an implication here that it might be possible to
> compile a php
> version of mapscript without the php source tree now? This could make
> rpm'i'fication of a swig'ed php mapscript much more straightforward.
> P.
Just checked on RedHat 7.3, the php-devel package contains everything
needed to compile PHP mapscript. So I guess anything newer than this
should be OK :)
Cheers,
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
