[Mapserver-dev] Raster Queries
Vincent Schut
schut at sarvision.com
Mon Mar 22 04:54:29 EST 2004
Frank,
just to fill in for your cat: Good work! Keep it going! Miauw!
On Friday 19 March 2004 19:09, Frank Warmerdam wrote:
> Woot!
> I can now do some very simple raster queries. The following simple
> query script executes properly against a raster layer.
> #!/usr/bin/env python
> import mapscript
> import sys
> map = mapscript.Map('rquery.map')
> layer = map.getLayer(0)
> rect = mapscript.Rect()
> rect.minx = 440720
> rect.maxx = 440780
> rect.miny = 3751260
> rect.maxy = 3751320
> layer.queryByRect( map, rect )
> layer.open()
> for i in range(1000):
> result = layer.getResult( i )
> if result is None:
> break
> print '(%d,%d,%s)' % (result.shapeindex,
> result.tileindex,result.classindex)
> s = layer.getShape( result.shapeindex, result.tileindex )
> print s
> for i in range(layer.numitems):
> print '%s: %s' % (layer.getItem(i), s.getValue(i))
> layer.close()
> map = None
> mapscript.msCleanup()
> And reports the following for the small 2x2 query rectangle:
> (0,0,)
> <C shapeObj instance at _808d1808_p_shapeObj>
> x: 440720
> y: 3751320
> value: 107
> (1,0,)
> <C shapeObj instance at _b8231908_p_shapeObj>
> x: 440780
> y: 3751320
> value: 123
> (2,0,)
> x: 440720
> y: 3751260
> value: 115
> (3,0,)
> <C shapeObj instance at _f0961a08_p_shapeObj>
> x: 440780
> y: 3751260
> value: 132
> As you can see, I have taken the approach of turning raster query results
> into internal data arrays that can then be access normally via the opening
> the layer and reading the shapes. I haven't tested it yet, but the query
> template engine should work without any special knowledge about rasters.
> I haven't yet added red, green, blue and class into the query results.
> Does it make more sense to return the class number or the class name in the
> query results?
> I also haven't gotten the histogramming support working yet or some of the
> query types (at a point, within a polygon, etc). However, I felt the need
> to good a Woot somewhere for my breakthrough. The problem with working in
> my basement is it is hard to impress the cat when I get something working.
> Best regards,
Vincent Schut
SarVision B.V.
Wageningen, The Netherlands
www.sarvision.com
