[Mapserver-dev] [Mapserver-users] Perl Mapscript 4 $image->free() bug
Eric Bridger
eric at gomoos.org
Tue May 4 16:00:25 EDT 2004
Moving my Perl mapscript scripts to mapserver 4.0.2 and 4.2 beta1 I've
discovered a problem with the imageObj->free() method.
I think I recall some recent posts with similiar problems on FreeBSD
systems.
We are running: FreeBSD 4.8, Perl5.8.0
Both:
MapServer version 4.2-beta1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
MapServer version 4.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=POSTGIS INPUT=OGR
--without-tiff GDAL 1.1.9
At first I thought it might be an Apache/mod_perl issue. Apache log
showed messages like:
httpd in free(): warning: junk pointer, too high to make sense
mapserver.log showed occasional:
Tue May 4 14:33:30 2004 - msFreeImage(): General error message. Unknown
image type
But the short script and map file below, run from the command line
produces ~ 900:
perl in free(): warning: page is already free
perl in free(): warning: junk pointer, too high to make sense
perl in free(): warning: chunk is already free
Simple work around is to stop using $imageObj->free() which fixes the
problem.
======= free_test.pl ================
#!/usr/bin/perl
use strict;
use mapscript4;
#OR
#use mapscript42;
$ENV{MS_ERRORFILE} = '/tmp/mapserver4.log';
my $image_name = "free_test.png";
my $map = new mapscript4::mapObj("free_test.map");
if(!$map){
warn "New mapObj() error: $mapscript4::ms_error->{message}\n";
my $img = $map->draw();
if(!$img){
warn "map->draw() error: $mapscript4::ms_error->{message}\n";
$map->drawLabelCache($img);
$img->save($image_name);
# This causes core dump. w/o it works fine.
$img->free();
exit;
======== free_test.map =================
MAP
STATUS ON
EXTENT -71.50 39.5 -63.0 46.0 # MINX MINY MAXX MAXY
SIZE 600 459
IMAGETYPE PNG
UNITS DD
IMAGECOLOR 152 245 255
OUTPUTFORMAT
NAME PNG
DRIVER "GD/PNG"
MIMETYPE "image/png"
# 24bit
#IMAGEMODE RGB
# 8 bit
IMAGEMODE PC256
EXTENSION "png"
END
PROJECTION
"proj=latlong"
END
LAYER
NAME "gom_states"
TYPE POLYGON
STATUS DEFAULT
DATA
"/home/www/gomoos.org/data/mapserver/vector/usgs/states/land_east"
CLASS
STYLE
OUTLINECOLOR 162 193 194
COLOR 255 255 204
END
END
PROJECTION
"proj=latlong"
END
END
END
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
