[Mapserver-dev] Rotated Map Rendering
Frank Warmerdam
warmerdam at pobox.com
Wed May 5 08:38:56 EDT 2004
Folks,
Tydac AG would like to be able to render rotated map views with MapServer.
I have prepared the following proposal for changes I would like to make
to make this possible.
The approach is essentially to hold the rotational transformation down
within the projectionObj for the map. The map will "think" it has a
north up coordinate system still so it can continue to use the mapObj->extents
as it does now in all the rendering code.
Any objections to be pursuing this in the 4.3 tree?
It is hoped that support for non-square pixels will also fall out of this
work, allowing us to complete WMS conformance testing.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
MapServer Rotated Map Support Proposal
Overall Approach
We will provide a new directive, and corresponding MapScript calls to set
a rotated extent based on a center point, width/height and rotation angle.
Internally a "fake" rotated coordiante system will be maintained for the
mapObj and all projection routines will know how to apply the extra step to
map from true map projections coordinates to this fake coordinate system. This
fake coordinate system will internally still have a seemingly north-up map.
Caveats and Notes
o The rotation effect will only cause an alteration in function in
msDrawMap(). It should have no effect on query mode or other operations.
o The rotated coordinate system should not be used with OGC WMS protocol
as there is no way to communicate an appropriate BBOX.
o There is some confusion still in my mind about how what means we will
have for interacting with the rotation mode via CGI if any. The
emphasis is to make it easily used from MapScript and raw .map files
for now.
o There may be some confusing issues with scale testing.
o Text angles will be relative to the rotated map coordinate system.
o Reference map drawing will not currently be updated to handle proper
rotated reference area display.
New Map File Directive
EXTENT_ROT <center_x> <center_y> <width> <height> <rotation_angle>
<center_x>,<center_y> - center of view window in projected coordinates.
<width><height> - width and height of window in projected units(meters/degrees)
<rotation_angle> - counter-clockwise rotation of view in degrees.
This keyword and the setExtentRot() method in MapScript will set the mapObj
extents rectObj to be exactly the same size as the rotated view, but
unrotated. This unrotated extent will cause a correct cellsize to be
set, but in fact, will not include quite all the data that will be needed
for the rotated render.
MapScript
New methods:
map->setExtentRot( center_x, center_y, width, height, rotation_angle )
Documentation
Updates will be made to the mapfile reference, and PHP and non-PHP MapScript
documentation briefly explaining the new rotation mode. A mini-HOWTO on
generation of rotated maps will be added to the Wiki.
Data Structure Changes
The mapObj will include following extra parameters:
// EXTENT_ROT
int using_ext_rot;
double ext_rot_center_x;
double ext_rot_center_y;
double ext_rot_width;
double ext_rot_height;
double ext_rot_rotation_angle;
// This is the affine transformation from pixel/line coordinates to
// pixel/line coordinates.
double extent_geotransform[6];
double extent_invgeotransform[6];
The projectionObj will include the following extra parameters:
int using_geotransform;
double pixel_to_proj_geotransform[6];
double proj_to_pixel_geotransform[6];
Computations
mapObj->extent_geotransform[] computation:
gt[0] = ext_rot_center_x
- 0.5 * (cos(rot_angle)*ext_rot_width - sin(rot_angle)*ext_rot_height)
gt[1] = cos(rot_angle) * ext_rot_width / mapObj->width
gt[2] = sin(rot_angle) * ext_rot_height / mapObject->height
gt[3] = ext_rot_center_y
+ 0.5 * (sin(rot_angle)*ext_rot_width + cos(rot_angle)*ext_rot_height)
gt[4] = sin(rot_angle) * ext_rot_width / mapObj->width
gt[5] = -cos(rot_angle) * ext_rot_height / mapObj->height
mapObj->extent_invgeotransform[] is computed fro extent_geotransform[] using
InvGeoTransform() in mapresample.c (invert affine transform).
Note that this definition of geotransform[] maps from a coordinate system
with x going from 0 to width (in pixels) and y going from height to 0 (in
pixels). This is a nice well behaved coordinate system from the point
of view of the rendering. Note that the mapObj->cellsize will be 1.0.
A "rotated map coordinate system" coordinate would be converted to real map
projected coordinates with the transformation:
x_real = gt[0] + x_fake * gt[1] + y_fake * gt[2]
y_real = gt[3] + x_fake * gt[4] + y_fake * gt[5]
The reverse just uses the inverted geotransform.
msDrawMap() Alterations
Within msDrawMap() (used for WMS renders, regular cgi renders and full
renders from MapScript) we will take the following steps:
o Copy the extent_geotransform[] and extent_invgeotransform[] to the
mapObj->projection pixel_to_proj_geotransform[] and
proj_to_pixel_geotransform[] fields, and set projection "using_geotransform"
flag.
o Update the mapObj->extent to have coordinates that produce the desired
region in the altered (rotated) coordinate system (set to 0 0 width height).
o On exit, the mapObj->projection->using_geotransform will be disabled and
mapObj->extent values will be restored to it's original value.
o Note that because this is being done at the drawMap() level, explicit
MapScript drawLayer() calls will ignore our rotation.
mapproject.c Alterations
In msProjectPoint() if using_geotransform is TRUE, apply the appropriate
geotransform when going to or from the map's projection.
In msProjectionsDiffer(), ensure that TRUE is returned if a geotransform
is in effect.
Raster Renderer
The raster renderer does not go through msProjectPoint() and friends in
the resampler. Extra code will need to be added to apply the geotransform
when enabled. Note that because the map projection will differ from the
file projection (due to the geotrasform) rotated maps will always be
processed through the mapresample.c code rather than through the more
direct code. This does imply some performance reduction if reprojection
of the image was not otherwise going to take place.
