[Mapserver-dev] HISTORY.TXT in v4.2
Sean Gillies sgillies at frii.com
Tue May 11 11:28:06 EDT 2004
On 11/mag/04, at 08:58, Daniel Morissette wrote:
> Hi,
> Several fixes to the 4.2 branch have been committed in the last few
> days without any comment in the HISTORY.TXT.
> For the 4.3 dev version, I think it's ok to document only the major
> changes and fixes, but for the (oon to be) stable 4.2 branch I think
> that every fix needs to be documented in HISTORY.TXT with refrerence
> to the bug number when appropriate.
> I know some of you already maintain the HISTORY.TXT very well, but for
> those who don't, please, please, please... add a note to HISTORY.TXT
> for *every* fix that you make in the stable 4.2 branch.
> Thanks
That was probably me.  Added function prototypes to map.h and completed
a number of
other protypes elsewhere so that the SWIG mapscript build would not
generate so
many warnings.  Committed an entry to HISTORY.TXT.
Sean
