[Mapserver-dev] error in Mapserver compilation
Sean Gillies
sgillies at frii.com
Fri May 14 10:02:27 EDT 2004
On May 14, 2004, at 7:43 AM, Vázquez Cascales, Sebastián wrote:
> Hello everybody!
> I'm a newbie to mapserver. I'm wanting to compile mapserver4.0
> in win32 as part of a proyect. The final goal is building a simple gis
> service in plone.
> http://plonemap.makina-corpus.org/map (this one seems to be working
> in a linux box)
> One of the problems that I have found is about mapows.c. At
> compilation time I'm given an error
> C:\plonemap\mapserver-4.0>nmake /f Makefile.vc
> Microsoft (R) Program Maintenance Utility Version 6.00.8168.0
> Copyright (C) Microsoft Corp 1988-1998. All rights reserved.
> cl /nologo /Zi /W3 /DDEBUG -DWIN32 -D_WIN32
> -IC:\plonemap\mapserver-4.0\
> gd-2.0.23 -IC:\plonemap\mapserver-4.0\regex-0.12
> \gdal-1.2.0/gcore -IC:\plonemap\mapserver-4.0\gdal-1.2.0/alg
> -IC:\plonemap\mapse
> rver-4.0\gdal-1.2.0/ogr/ogrsf_frmts
> -IC:\plonemap\mapserver-4.0\gdal-1.2.0/ogr -
> IC:\plonemap\mapserver-4.0\gdal-1.2.0/ogr/../port
> -Ic:/projects/curl-7.10.2/inc
> lude -DHAVE_STRING_H -DREGEX_MALLOC -DNEED_STRCASECMP
> -DNEED_STRNCASECMP
> -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_GIF
> -DGD_HAS_GDIMAGEGIFPT
> R -DUSE_GD_FT -DUSE_OGR -DUSE_WMS_SVR -DUSE_WMS_LYR
> -DIGNORE_MISSING_DATA -DUS
> E_GDAL -DFEATURE_INFO_HTML -DUSE_WFS_SVR -DUSE_WFS_LYR
> -DUSE_GD_ANTIALIAS /c
> mapows.c /Fomapows.obj
> mapows.c
> mapows.c(196) : warning C4090: 'function' : different 'const'
> qualifiers
> mapows.c(196) : warning C4024: 'strcasecmp' : different types for
> formal and act
> ual parameter 1
> mapows.c(439) : error C2223: left of '->is_latlong' must point to
> struct/union
> mapows.c(497) : warning C4090: 'function' : different 'const'
> qualifiers
> mapows.c(497) : warning C4024: 'strcasecmp' : different types for
> formal and act
> ual parameter 1
> mapows.c(734) : warning C4018: '!=' : signed/unsigned mismatch
> NMAKE : fatal error U1077: 'cl' : return code '0x2'
> Stop.
> it's included as an entry in Makefile.vc. Can I remove it? The issue
> is that I don't know if I need OGC web services.
> Honestly, I'm not a programer!!
> thanks in advance
Hi Sebastián,
To use the Plone map you will not need OGC capabilities.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
