[Mapserver-dev] error in Mapserver compilation
Daniel Morissette
dmorissette at dmsolutions.ca
Fri May 14 10:03:26 EDT 2004
Vázquez Cascales, Sebastián wrote:
> it's included as an entry in Makefile.vc. Can I remove it? The issue is
> that I don't know if I need OGC web services.
> Honestly, I'm not a programer!!
Why try to build yourself? (especially if you're not experienced with
C/C++ programming) I would recommend that you use the precompiled
binaries available on the website.
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
