[Mapserver-dev] error in Mapserver compilation
Sean Gillies sgillies at frii.com
Fri May 14 10:23:50 EDT 2004
On May 14, 2004, at 8:03 AM, Daniel Morissette wrote:
> Vázquez Cascales, Sebastián wrote:
>> it's included as an entry in Makefile.vc. Can I remove it? The issue
>> is that I don't know if I need OGC web services.
>> Honestly, I'm not a programer!!
> Why try to build yourself? (especially if you're not experienced with
> C/C++ programming) I would recommend that you use the precompiled
> binaries available on the website.
Because he needs the mapscript module for Python, and probably needs to
build it using
the Python binary that is distributed with the Win32 Zope/Plone
software.
There's a Python mapscript module in OpenEV, but it is from the 4.3
branch and only for
Python 2.2.  The stable Zope is using Python 2.1.3.
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
