[Mapserver-dev] error in Mapserver compilation
Frank Warmerdam
warmerdam at pobox.com
Fri May 14 10:13:01 EDT 2004
Vázquez Cascales, Sebastián wrote:
> mapows.c(196) : warning C4090: 'function' : different 'const' qualifiers
> mapows.c(196) : warning C4024: 'strcasecmp' : different types for formal
> and act
> ual parameter 1
> mapows.c(439) : error C2223: left of '->is_latlong' must point to
> struct/union
> mapows.c(497) : warning C4090: 'function' : different 'const' qualifiers
> mapows.c(497) : warning C4024: 'strcasecmp' : different types for formal
> and act
> ual parameter 1
> mapows.c(734) : warning C4018: '!=' : signed/unsigned mismatch
> NMAKE : fatal error U1077: 'cl' : return code '0x2'
> Stop.
> it's included as an entry in Makefile.vc. Can I remove it? The issue is
> that I don't know if I need OGC web services.
The above stuff about is_latlong suggests to me that you might be using a
version of PROJ.4 that is too old.
> Honestly, I'm not a programer!!
I believe you, and building MapServer from source on windows is not for the
faint of heart.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
