[Mapserver-dev] Serious conflict with other php packages
Daniel Morissette dmorissette at dmsolutions.ca
Fri May 21 16:22:03 EDT 2004
Rodrigues, Joseph wrote:
> The known problem:
>  Chartdirector has a Class called 'Line' and 'Layer' and causes a
> conflict with php as phpmapscript has classes with the same name.  The
> result is neither works without changing the one class name.
> I use Mapserver with phpmapscript to build charts on the fly and graph
> them using Chartdirector.  I want to suggest a name change to MSLine and
> MSLayer or anything else of your choice to differentiate from such
> generic names as Line and Layer.  I made a similar suggestion to Peter
> Kwan of Chartdirector.
I have filed a bug about this, we'll try to do something about this for
the 4.4 release: http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=672
  DM Solutions Group              http://www.dmsolutions.ca/
