[Mapserver-dev] Serious conflict with other php packages
Daniel Morissette dmorissette at dmsolutions.ca
Fri May 21 18:47:16 EDT 2004
Daniel Morissette wrote:
> Rodrigues, Joseph wrote:
>> The known problem:
>>  Chartdirector has a Class called 'Line' and 'Layer' and causes a
>> conflict with php as phpmapscript has classes with the same name.  The
>> result is neither works without changing the one class name.
>> I use Mapserver with phpmapscript to build charts on the fly and graph
>> them using Chartdirector.  I want to suggest a name change to MSLine and
>> MSLayer or anything else of your choice to differentiate from such
>> generic names as Line and Layer.  I made a similar suggestion to Peter
>> Kwan of Chartdirector.
> I have filed a bug about this, we'll try to do something about this for
> the 4.4 release: http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=672
For the record, I just found this was already fixed about 1 year ago
before the release of V4.0.  So this would happen only with v3.6 or
older and upgrading to 4.0 or 4.2 will solve the issue for you.
  DM Solutions Group              http://www.dmsolutions.ca/
