[Fwd: Re: [UMN_MAPSERVER-DEV] single classed layers and
GetLegendGraphic]
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Wed Nov 10 08:43:07 EST 2004
> -----Original Message-----
> From: bartvde at xs4all.nl [mailto:bartvde at xs4all.nl]
> Sent: Wednesday, 10 November, 2004 02:33
> To: Kralidis,Tom [Burlington]
> Cc: mapserver-dev at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-DEV] [Fwd: Re:
> [UMN_MAPSERVER-DEV] single classed layers and GetLegendGraphic]
> For reference, this was my original post on the wms-dev list.
> http://lists.eogeo.org/pipermail/wms-dev/2004-May/000518.html
> The answer Keith gave only applied to the case of multiple
> rules, but I did not suspect this behaviour to be different
> from the case where there is only one rule ... but apparently
> it is in Cubewerx's implementation ...
> I do see Tom has a point now, but still think the spec is not
> fully well-thought at the moment ...
> Tom, btw what is your purpose for only getting the legend
> graphic without a label in the case of a single class layer?
> Are you putting the wms_title next to the legend graphic in
> the WMS client (or using no label at all?), because otherwise
> you need to know the name of the Rule anyway to put it next
> to the legend graphic (and use a GetStyles request to know this name).
Yes, I'm basically writing out a table like:
Icon|Title
Icon|Title
...so it's a bit redundant if the title is shown twice.
> Btw2: does Cubewerx use the GetLegend request in their LegendURL?
No, it's a vendor specific thing they use in CubeXPLOR.
> Best regards,
> Bart
> >> As I wrote already, I agree that this may be a valid
> interpretation,
> >> and that was our initial interpretation of the spec.
> However the spec
> >> is vague on this and in bug 653 it was requested that we align
> >> MapServer's
> >> behavior with other (prior) implementations (cubeserv) so
> >> that clients
> >> can better interoperate.
> > Here are my CubeSERV observations:
> > CubeSERV OGC:WMS 1.1.1 GetLegendGraphic requests:
> > This is a layer with multiple classes:
> http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi?servic
> > e=
> WMS&version=1.1.1&request=GetLegendGraphic&layer=CANADNAODA_L%
> 3ACEOWARE2
> > &format=image/png
> > This is a layer with a single class (i.e. all point symbols are the
> > same)
> http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi?versio
> > n=
> 1.1.1&service=WMS&request=GetLegendGraphic&layer=GCDB_INDEX:CE
> OWARE2&for
> > mat=image/png
> > The layer title does not show up as part of the image. This is
> > default behaviour.
> > Here is the same layer (single class) with the layer name
> embedded in
> > image via 'GetLegend'
> > n=
> 1.1.1&service=WMS&request=GetLegend&layers=GCDB_INDEX:CEOWARE2
> &format=im
> > age/png
> > Here are both layers in a GetLegend:
> > n=
> ,CANADNAOD
> > A_L:CEOWARE2&format=image/png
> > ..Tom
