Mapserver-4.4.0-beta2 wms client rendering problem
Frank Warmerdam warmerdam at POBOX.COM
Wed Nov 10 09:17:02 EST 2004
Lars Holm Loldrup wrote:
> Rendering a wms client layer, the image is slight distorted, and shifted
> 1 pixel north-west - se the attached images: 1.png is the original from
> the wms-server, and 2.png is the resulting image that mapserver
> generates.
> Observerd on my own win32 build & on the win32 version from
> http://dl.maptools.org/dl/
Lars,
OK, I see the resulting problem.  Can you file a bug (and have it assigned
to me) that shows the steps to reproduce this?  Ideally a mapfile with just
the WMS layer, and a mapserv request that will generate the slightly offset
result.
I *suspect* that the world file attached internally to images fetched from
remote WMS'es is off by half a pixel and this is causing a sampling error
or offset.
> BTW. The true color bug
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=468
> seems to be resolved in beta2.
OK, I have close it now.
Best regards,
