mapserver and XML status?
Bart van den Eijnden
bartvde at XS4ALL.NL
Fri Nov 12 13:27:46 EST 2004
end of last year Sean Gillies started something on the Wiki, but AFAIK it
never got off the ground:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MapScriptXMLDataModelProjectProposal
In the OGC world (WMS,WFS,WCS) SOAP is slowly starting to become
incorporated, Ionic, a company from Belgium has written SOAP wrappers for
all the major OGC protocols, during the OWS-2 (OpenGIS Web Services)
testbed.
Best regards,
Bart
On Fri, 12 Nov 2004 11:51:14 -0500, Terry Brown <tbrown at NRRI.UMN.EDU>
wrote:
> What the status of mapserver vis-a-vis XML technologies?
> Particularly for the mapfile end of things - I see the mapfile.dtd
> in the source tree, but that seems incomplete.
> I saw some comment about not wanting to introduce XML-Schemas
> because the only open source tools to handle them require C++ (or
> Java), and you don't want to add more dependencies to mapserver.
> But it seems to me that XML components could be developed along side
> mapserver without making mapserver dependent on them - e.g. a schema
> for writing map files in XML with an XSLT translation to the current
> ascii mapfile format in the mean time, so those who wanted could use
> it. I know it's difficult once you let XML get its toe in the door,
> where to draw the line, do you fold a lot of documentation into the
> schema, etc. etc.
> Does this sound like something that might be useful? I'd be up for
> writing a draft XML-Schema with an automatic translation to a DTD as
> a starting point.
> Out of curiosity and strictly as an aside, do the cross server
> interchange protocols (WMS?) use web services / SOAP type
> technologies at all?
> Cheers -Terry
> Terry Brown Natural Resources Research Institute
> Research Associate 5013 Miller Trunk Highway
> tbrown at nrri.umn.edu University of Minnesota, Duluth
> Ph. 218 720 4345 Duluth, Minnesota 55811
> Fax 218 720 4328 http://beaver.nrri.umn.edu/~tbrown/
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
