SDE raster support
Frank Warmerdam
warmerdam at POBOX.COM
Sat Nov 13 13:14:40 EST 2004
Paul Ramsey wrote:
> Wouldn't one of the major benefits be the tie-in to connection pooling
> via mapsde? Speaking from bitter experience, SDE without connection
> pooling is worth less than a bucket of warm spit. :)
> Or can (will) GDAL connections take advantage of the pool now too?
> Paul
Paul,
GDAL does not utilize MapServer level connection pooling currently; however,
it does - in some cases - implement connection pooling internally. I am not
adverse to improving MapServer/GDAL connection pooling integration for drivers
where it would provide a benefit. However, this is one of several reasons why
integrating the SourcePole SDE Raster support into GDAL would be a substantial
job.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
