SDE raster support
Paul Ramsey pramsey at REFRACTIONS.NET
Fri Nov 12 19:03:16 EST 2004
Wouldn't one of the major benefits be the tie-in to connection pooling
via mapsde?  Speaking from bitter experience, SDE without connection
pooling is worth less than a bucket of warm spit. :)
Or can (will) GDAL connections take advantage of the pool now too?
Paul
On 12-Nov-04, at 2:44 PM, Daniel Morissette wrote:
> Frank Warmerdam wrote:
>> SDE Raster, cool!
>> I looked at the implementation and I would be happy enough to have the
>> drawSDE hook added to mapraster.c if Howard is OK with the addition(s)
>> to mapsde.c, and Daniel is OK with doing it before the 4.4. release.
>> I can imagine they both might be hesitant about a substantial
>> addition at
>> this late date, in which case it might end up having to wait for
>> integration
>> till post 4.4 (ie 4.5).
> We talked about this with Steve and Howard on IRC a few minutes ago
> (you
> were gone, sorry), and we agreed that it would be best to wait until
> after 4.4, and to look at adapting the patch to work through GDAL
> unless
> there are benefits to sticking with a native implementation.
> Another question that came up was long term support if we add this to
> MapServer: are you ready to support this in the long run Pirmin?
> Daniel
>  Daniel Morissette               dmorissette at dmsolutions.ca
>  DM Solutions Group              http://www.dmsolutions.ca/
