SDE raster support
Frank Warmerdam warmerdam at POBOX.COM
Mon Nov 15 14:42:58 EST 2004
 >Frank Warmerdam wrote:
>>I notice that your version of mapsde.c does not include Howards recent
>>upgrades for connection pooling support.  Hopefully it won't be too hard
>>to bridge that gap.  In fact, you might want to consider preparing a formal
>>patch agaist the current development tree so your changes can be more
>>easiliy integrated.
Pirmin Kalberer wrote:
> It should be no problem. We could create a patch and test it, if the mapserver
> people want to have it integrated it in the current CVS version. There is only
> a absolutely minimal change in the non-raster SDE part, so I see no risk in
> adding it now.
Pirmin,
OK, I believe Howard and I have committed the necessary pieces into the 4.4
tree in time for beta3 without any active resistance from our esteemed
release manager.  Howard has agreed to be the official scape goat if this
causes problems, but I would strongly encourage you to extract MapServer from
CVS and do a bit of testing of the SDE raster support as commited to ensure it
still works properly. I am no posisition to test it myself (or even build it).
Best regards,
