sderaster.h - version problems?
Howard Butler hobu at IASTATE.EDU
Wed Nov 17 10:22:00 EST 2004
Havard,
Yes there should be a version check.  For 4.4, SDE raster will be listed as
"experimental", similar to WCS support in the previous release and will
have to be explicitly turned on.
The symbol to do so will be -DUSE_SDERASTER
Howard
At 08:10 AM 11/17/2004, Havard Tveite wrote:
>I tried to build from CVS now, and mapsde.c would no longer compile.
>Several symbols are missing (SE_COLORMAP_DATA_TYPE, ...). I checked my
>sderaster.h (1.23 1999/10/22 - ArcSDE8), and these constants were not
>defined. I found another version of sderaster.h (v 1.43 2003/10/07)
>out there and it contained SE_COLORMAP_DATA_TYPE.
>Is my old version of ArcSDE no longer supported?
>Should there be a version check?
>Håvard Tveite
>Department of Mathematical Sciences and Technology
>Agricultural University of Norway
>Drøbakveien 14, POBox 5003, N-1432 Ås, NORWAY
>Phone: +47 64948857 Fax: +47 64948810 http://www.nlh.no/imt
