Handling special characters
Palanisamy, Giri
palanisamyg at ORNL.GOV
Fri Nov 19 16:28:32 EST 2004
Hi Daniel,
The output displayed as "ñ", OK I will file a bug.
Thanks!
Giri
-----Original Message-----
From: UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU]
On Behalf Of Daniel Morissette
Sent: Friday, November 19, 2004 4:15 PM
To: MAPSERVER-DEV at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-DEV] Handling special characters
Palanisamy, Giri wrote:
> The numbers (ñ) also just displayed as numbers, didn't convert it
to special characters!
Displayed as "ñ" or as garbage? If you got garbage then it might be
that your TTF font doesn't include this character or is in a different
encoding (in which case the new iconv stuff from bug 858 may help).
If you get "ñ" as output then I'd suggest that you file a bug with
a *complete* testcase to reproduce (mapfile, data, etc.).
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
