win32 MapServer builds
Frank Warmerdam
warmerdam at POBOX.COM
Tue Nov 23 12:17:35 EST 2004
Assefa,
I am intrested in reworking the default configuration of the mapserver
win32 builds somewhat with the following in mind:
o Default to assuming folks are building against the bgd GD DLLs with all the
stuff they include.
o Disable (comment out) all the optional packages (ming, pdf, gdal, curl, etc)
by default.
o Move OPTFLAGS and LDFLAGS from makefile.vc to nmake.opt since they
frequently need to be changed.
o Use /MD by default, since many support libraries like GDAL and PROJ.4 are
built that way by default. Statically linking proj.lib in (that was built
with /MD) with a non-/MD mapserver is bad karma.
In general, I would like to make building a simple MapServer build alot easier,
and then let people add stuff to that rather than starting with lots of stuff
broken.
Also, using the pre-built GD makes *alot* of stuff easier.
What do you think? Mind if I "do a number" on makefile.vc and nmake.opt?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
