win32 MapServer builds
Bart van den Eijnden
bartvde at XS4ALL.NL
Tue Nov 23 14:36:44 EST 2004
Hi Frank,
I would be happy to be a testcase for this new setup, if I will be able to
build using this setup, most users will be as well :)
Let me know if you want me to test.
Best regards,
Bart
On Tue, 23 Nov 2004 12:17:35 -0500, Frank Warmerdam <warmerdam at POBOX.COM>
wrote:
> Assefa,
> I am intrested in reworking the default configuration of the mapserver
> win32 builds somewhat with the following in mind:
> o Default to assuming folks are building against the bgd GD DLLs with
> all the
> stuff they include.
> o Disable (comment out) all the optional packages (ming, pdf, gdal,
> curl, etc)
> by default.
> o Move OPTFLAGS and LDFLAGS from makefile.vc to nmake.opt since they
> frequently need to be changed.
> o Use /MD by default, since many support libraries like GDAL and
> PROJ.4 are
> built that way by default. Statically linking proj.lib in (that was
> built
> with /MD) with a non-/MD mapserver is bad karma.
> In general, I would like to make building a simple MapServer build alot
> easier,
> and then let people add stuff to that rather than starting with lots of
> stuff
> broken.
> Also, using the pre-built GD makes *alot* of stuff easier.
> What do you think? Mind if I "do a number" on makefile.vc and nmake.opt?
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
