win32 MapServer builds
Valik Solórzano Barboza
valik.solorzano.barboza at GEODAN.NL
Wed Nov 24 07:51:25 EST 2004
Frank,
I would think that adding some flag when building which tells whether it's
a release or debug version would be very handy. I made some changes to
makefile.vc and nmake.opt see the below (changes made based on the head
version from CVS).
makefile.vc
#MY CHANGES
!IFDEF BUILD_DEBUG
OPTFLAGS = /nologo /Od /MTd /Zi /Fdmapserv.pdb $(WARNING_LEVEL) $(DEBUG)
BASE_CFLAGS = $(OPTFLAGS) -DWIN32 -D_WIN32
LDFLAGS = $(LDEBUG) /NODEFAULTLIB:libcmtd /pdb:"mapserv.pdb"
!ELSE
OPTFLAGS = /nologo /MT $(WARNING_LEVEL) $(DEBUG)
LDFLAGS = $(LDEBUG)
!ENDIF
$(MS_LIB): $(MS_OBJS)
if exist $(GDAL_DIR)\gdal.pdb copy $(GDAL_DIR)\gdal.pdb .
lib /out:$(MS_LIB) $(MS_OBJS)
link /dll $(LDEBUG) \
$(MS_OBJS) $(EXTERNAL_LIBS) /def:mapserver.def \
/out:$(MS_DLL) /implib:$(MS_LIB_DLL)
#ORIGINAL
OPTFLAGS = /nologo /Zi $(WARNING_LEVEL) $(DEBUG)
LDFLAGS = /NODEFAULTLIB:msvcrt /NODEFAULTLIB:libcd /DEBUG
link /dll /debug \
and in
nmake.opt
#MY CHANGES
# Section III: Debug flags
# Should not need to be updated.
!IFDEF BUILD_DEBUG
# DEBUG Build flags
# Set the DEBUG flag if you wish to make a debug build
DEBUG=/DDEBUG
# Set the Warning level for the compiler (defaults to W1)
WARNING_LEVEL=/W3
# Set the linker debug option
LDEBUG=/debug
!ELSE
# DEBUG Build flags
DEBUG=
WARNING_LEVEL=/W3
LDEBUG=
!ENDIF
#ORIGINAL
# DEBUG Build flags
DEBUG=/DDEBUG
WARNING_LEVEL=/W3
LDEBUG=/debug
But for the above changes to be usefull I had to change other makefiles and
nmake.opt (if you are interested I can send you the files I had to change):
- freetype
- gd
- gdal
- jpeg
- libpng
- proj
I would actually advise to use /MT (static linkage of the runtime
libraries). My experience with the runtime libraries (MSVCT**.DLL) are not
very nice. And offcourse this also could be made configurable trough
commandline flags for the NMAKE command.
Cheers,
Valik
At 18:17 23/11/2004, Frank Warmerdam wrote:
>Assefa,
>I am intrested in reworking the default configuration of the mapserver
>win32 builds somewhat with the following in mind:
> o Default to assuming folks are building against the bgd GD DLLs with
> all the
> stuff they include.
> o Disable (comment out) all the optional packages (ming, pdf, gdal,
> curl, etc)
> by default.
> o Move OPTFLAGS and LDFLAGS from makefile.vc to nmake.opt since they
> frequently need to be changed.
> o Use /MD by default, since many support libraries like GDAL and PROJ.4 are
> built that way by default. Statically linking proj.lib in (that was built
> with /MD) with a non-/MD mapserver is bad karma.
>In general, I would like to make building a simple MapServer build alot
>easier,
>and then let people add stuff to that rather than starting with lots of stuff
>broken.
>Also, using the pre-built GD makes *alot* of stuff easier.
>What do you think? Mind if I "do a number" on makefile.vc and nmake.opt?
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | Geospatial Programmer for Rent
Drs. Valik Solórzano Barboza
Geodan SDT b.v.
President Kennedylaan 1
1079 MB Amsterdam (NL)
Tel: +31 (0)20 - 5711 311
Fax: +31 (0)20 - 5711 333
E-mail: valik.solorzano.barboza at geodan.nl
Website: www.geodan.nl
Disclaimer: www.geodan.nl/disclaimer
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20041124/1dab7ef5/attachment.html
