Please help: "map context is not enabled"
Daniel Morissette
dmorissette at DMSOLUTIONS.CA
Mon Nov 29 01:42:50 EST 2004
This is the MAPSERVER-DEV list. This list is intended for discussions on
mapserver development issues between the developers of the software.
Your questions should go to the MAPSERVER-USERS list.
Daniel
Xiongjiu Liao wrote:
> Hello, everyone:
> I am working on a project with Mapserver, but I meet some problems with
> it,
> would you please give some ideals? Really appreciate it.
> a) here is the error message:
> Warning: [MapServer Error]: msSaveMapContext(): Not implemented since Map
> Context is not enabled. in /www/htdocs/context_script.php on line 4
> Warning: Failed saving map context from gmap_wms_context_output.xml in
> b) here is the php program I want to test:
> <?php
> dl("php_mapscript.so");
> $oMap = ms_newMapObj("/www/htdocs/tutorial/context_test1.map");
> $oMap->saveMapContext("gmap_wms_context_output.xml");
> c) here is my Mapserver configure output:
> ./mapserv40 -v
> MapServer version 4.2.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> d) here is my mapfile:
> Map
> NAME EX3.1_
> status on
> PROJECTION
> "init=epsg:2163"
> END
> web
> IMAGEPATH '/www/htdocs/tutorial/data/tmp/'
> IMAGEURL '/tutorial/data/tmp/'
> METADATA
> "WMS_TITLE" "UMN MapServer Upper Great Lakes Application"
> "WMS_ONLINERESOURCE"
> "http://localhost/cgi-bin/mapserv40?map=context_test1.map&"
> "WMS_SRS" "EPSG:2163 EPSG:4326 EPSG:26915 EPSG:26916"
> END
> end
> LAYER
> NAME states
> DATA states_ugl
> STATUS DEFAULT
> TYPE POLYGON
> METADATA
> "wms_title" "Elevation/Bathymetry"
> "wms_srs" "EPSG:42304 EPSG:4269 EPSG:4326"
> END
> #CONNECTIONTYPE WMS
> #CONNECTION
> "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?#VERSION=1.1.0&LAYERS=bathymet
> ry&FORMAT=image/png"
> # PROJECTION
> # "init=epsg:42304"
> #END
> END
> end
> Thank you very much!
