[Mapserver-dev] OGC WMS GetFeatureInfo issues
Yewondwossen Assefa
assefa at dmsolutions.ca
Mon Oct 4 15:06:00 EDT 2004
Oops ... Another version of mapgml.c (r.1.41). I missed the default
value for the features name.
Kralidis,Tom [Burlington] wrote:
>>-----Original Message-----
>>From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
>>Sent: Monday, 04 October, 2004 14:25
>>To: Kralidis,Tom [Burlington]
>>Cc: Frank Warmerdam; mapserver-dev at lists.gis.umn.edu
>>Subject: Re: [Mapserver-dev] OGC WMS GetFeatureInfo issues
>>Tom,
>> I updated mapgml.c (r1.40) with the correction. GML
>>Structure is back
>>to normal.
> Not per 4.2.0. The record data returned is still one layer 'too high'
> (expecting a "layer_name_feature" tag).
> ..Tom
>>Later,
>>>>>From: Frank Warmerdam [mailto:warmerdam at pobox.com] Sent:
>>Monday, 04
>>>>>October, 2004 13:09
>>>>>Cc: mapserver-dev at lists.gis.umn.edu
>>>>>Tom,
>>>>>I have committed a small fix to mapows.c. Please cvs
>>update, build
>>>>>and try again. I now get GML back from the request
>>though I don't
>>>>>know for sure if everything is working properly.
>>>>I get GML back, however the structure looks a bit wierd (i.e. dips
>>>>into the feature right away). The returned structure is different
>>>>from previous MapServer versions of GML return.
>>>>i.e.:
>>>><?xml version="1.0" encoding="ISO-8859-1"?>
>>>><msGMLOutput xmlns:gml="http://www.opengis.net/gml"
>>>> xmlns:xlink="http://www.w3.org/1999/xlink"
>>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
>>>Tom,
>>>Hmm, that does look weird. I think you will need to take
>>it up with
>>>Julien as I am guessing it relates to his changes.
>>>Best regards,
>>Assefa Yewondwossen
>>Software Analyst
>>Email: assefa at dmsolutions.ca
>>http://www.dmsolutions.ca/
>>Phone: (613) 565-5056 (ext 14)
>>Fax: (613) 565-0925
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Fax: (613) 565-0925
