[Mapserver-dev] Re: mappool.c thoughts
Frank Warmerdam
warmerdam at pobox.com
Tue Oct 5 11:57:49 EDT 2004
Sean Gillies wrote:
> I think it's a good thing that our functions require just the bare minimum
> context. Passing a connection pool everywhere would suck. I'm happy with
> your proposed solution, with one additional suggestion.
> Let's consider adding a
> ConnectionPool *connectionpool
> member to layerObj. If NULL, we use the default module-level pool. In the
> mapscript case, it would reference an application-level pool. Calls to
> the msConnPool functions could be passed self->connectionpool.
Sean,
Sure, that sounds fine. I try to work on this in the next couple weeks.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
