[Mapserver-dev] Re: mappool.c thoughts
Sean Gillies sgillies at frii.com
Tue Oct 5 12:10:19 EDT 2004
On Oct 5, 2004, at 9:57 AM, Frank Warmerdam wrote:
> Sean Gillies wrote:
>  > I think it's a good thing that our functions require just the bare
> minimum
>> context.  Passing a connection pool everywhere would suck.  I'm happy
>> with
>> your proposed solution, with one additional suggestion.
>> Let's consider adding a
>>   ConnectionPool *connectionpool
>> member to layerObj.  If NULL, we use the default module-level pool.
>> In the
>> mapscript case, it would reference an application-level pool.  Calls
>> to
>> the msConnPool functions could be passed self->connectionpool.
> Sean,
> Sure, that sounds fine.  I try to work on this in the next couple
> weeks.
Great.  I'll work on the mapscript interface.
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
