[Mapserver-dev] ready for 4.2.4
Fernando S.
simon at inf.univali.br
Wed Oct 6 14:33:50 EDT 2004
Hi all,
Sorry, my fault.
Fernando Simon
Sean Gillies wrote:
> Fernando,
> I'm talking about a 4.2.4 release. Your new oraclespatial work should be
> committed to the CVS head, also known as 4.3, and will be released in
> 4.4.0.
> Sean
> On Oct 6, 2004, at 12:17 PM, Fernando S. wrote:
>> Hi,
>> I already finished the new features for maporaclespatial.c. But I
>> don't know if I can finish the OracleSpatial/FastCGI until 4.2.4
>> release. Only for 4.2.6 version. Any problem?
>> I'm writing a MapOracleSpatial guide with the new features, so how
>> and where I post this guide?
>> I intend to commit in CVS this friday.
>> Any hint?
>> Fernando Simon - simon at inf.univali.br
>> Mapserver and Oracle Spatial developer
>> G10 - Laboratorio de Computacao Aplicada
>> http://g10.cttmar.univali.br
>> Sean Gillies wrote:
>>> Hi all,
>>> The work I wanted to complete before a 4.2.4 release is done. My
>>> unit tests
>>> pass and are leak free. This doesn't mean that the software is 100%
>>> leak free,
>>> but it no longer leaks memory when exiting from common error states.
>>> I don't have any idea what others are using for regression tests,
>>> but will
>>> you run them and see if they pass?
>>> Below is an excerpt from HISTORY.TXT showing changes since 4.2.3.
>>> I'd also
>>> like to include with this release a file that describes known bugs.
>>> According to Bugzilla, there are 32 unresolved bugs in the 4.2 version.
>>> Of these, only 7 have been assigned. The rest remain with status
>>> "New".
>>> I'm not trying to pick on anybody, but if we all acted a bit more
>>> quickly
>>> to change status to "Assigned" or "Unconfirmed", it would be a lot
>>> easier
>>> to enumerate the known bugs in mapserver. I have a suggestion on
>>> this in
>>> another email.
>>> cheers,
>>> Sean
>>> Version 4.2.4
>>> - Various fixes allowing unit tests to run leak free under valgrind on
>>> i686. Memory is now properly freed when exiting from common error
>>> states (bug 927).
>>> - Restored ability to render transparent (indexed or alpha) pixmap
>>> symbols
>>> on RGB map images, including annotation layers and embedded
>>> scalebars.
>>> This feature remains OFF by default for map layers and is enabled by
>>> specifying TRANSPARENCY ALPHA (bugs 926, 490).
>>> - New and improved Java mapscript build provided by
>>> unicoletti at prometeo.it,
>>> and examples contributed by Y.K. Choo (bug 876).
>>> - Fixed bug 863: Output MapContext parameters (SRS and DataURL) in
>>> the order
>>> required by the spec.
>>> - searchImageCache() in mapgd.c now checks all three style colors
>>> before
>>> using a cached brush image (bug 868).
>>> - Fixed bug 857: Fix msDecodeHTMLEntities to not skip characters
>>> after each
>>> decoding.
>>> - Fixed bug 834: SE_ROW_ID in SDE not initialized for unregistered
>>> SDE tables
>>> Sean Gillies
>>> sgillies at frii dot com
>>> http://users.frii.com/sgillies
>>> Mapserver-dev mailing list
>>> Mapserver-dev at lists.gis.umn.edu
>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
