[Mapserver-dev] ready for 4.2.4
Sean Gillies
sgillies at frii.com
Wed Oct 6 14:24:57 EDT 2004
Fernando,
I'm talking about a 4.2.4 release. Your new oraclespatial work should
be
committed to the CVS head, also known as 4.3, and will be released in
4.4.0.
Sean
On Oct 6, 2004, at 12:17 PM, Fernando S. wrote:
> Hi,
> I already finished the new features for maporaclespatial.c. But I
> don't know if I can finish the OracleSpatial/FastCGI until 4.2.4
> release. Only for 4.2.6 version. Any problem?
> I'm writing a MapOracleSpatial guide with the new features, so how
> and where I post this guide?
> I intend to commit in CVS this friday.
> Any hint?
> Fernando Simon - simon at inf.univali.br
> Mapserver and Oracle Spatial developer
> G10 - Laboratorio de Computacao Aplicada
> http://g10.cttmar.univali.br
> Sean Gillies wrote:
>> Hi all,
>> The work I wanted to complete before a 4.2.4 release is done. My
>> unit tests
>> pass and are leak free. This doesn't mean that the software is 100%
>> leak free,
>> but it no longer leaks memory when exiting from common error states.
>> I don't have any idea what others are using for regression tests, but
>> will
>> you run them and see if they pass?
>> Below is an excerpt from HISTORY.TXT showing changes since 4.2.3.
>> I'd also
>> like to include with this release a file that describes known bugs.
>> According to Bugzilla, there are 32 unresolved bugs in the 4.2
>> version.
>> Of these, only 7 have been assigned. The rest remain with status
>> "New".
>> I'm not trying to pick on anybody, but if we all acted a bit more
>> quickly
>> to change status to "Assigned" or "Unconfirmed", it would be a lot
>> easier
>> to enumerate the known bugs in mapserver. I have a suggestion on
>> this in
>> another email.
>> cheers,
>> Sean
>> Version 4.2.4
>> - Various fixes allowing unit tests to run leak free under valgrind on
>> i686. Memory is now properly freed when exiting from common error
>> states (bug 927).
>> - Restored ability to render transparent (indexed or alpha) pixmap
>> symbols
>> on RGB map images, including annotation layers and embedded
>> scalebars.
>> This feature remains OFF by default for map layers and is enabled by
>> specifying TRANSPARENCY ALPHA (bugs 926, 490).
>> - New and improved Java mapscript build provided by
>> unicoletti at prometeo.it,
>> and examples contributed by Y.K. Choo (bug 876).
>> - Fixed bug 863: Output MapContext parameters (SRS and DataURL) in
>> the order
>> required by the spec.
>> - searchImageCache() in mapgd.c now checks all three style colors
>> before
>> using a cached brush image (bug 868).
>> - Fixed bug 857: Fix msDecodeHTMLEntities to not skip characters
>> after each
>> decoding.
>> - Fixed bug 834: SE_ROW_ID in SDE not initialized for unregistered
>> SDE tables
>> Sean Gillies
>> sgillies at frii dot com
>> http://users.frii.com/sgillies
>> Mapserver-dev mailing list
>> Mapserver-dev at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
