[Mapserver-dev] ready for 4.2.4
Fernando S.
simon at inf.univali.br
Wed Oct 6 14:17:01 EDT 2004
I already finished the new features for maporaclespatial.c. But I
don't know if I can finish the OracleSpatial/FastCGI until 4.2.4
release. Only for 4.2.6 version. Any problem?
I'm writing a MapOracleSpatial guide with the new features, so how
and where I post this guide?
I intend to commit in CVS this friday.
Any hint?
Fernando Simon - simon at inf.univali.br
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada
http://g10.cttmar.univali.br
Sean Gillies wrote:
> Hi all,
> The work I wanted to complete before a 4.2.4 release is done. My unit
> tests
> pass and are leak free. This doesn't mean that the software is 100%
> leak free,
> but it no longer leaks memory when exiting from common error states.
> I don't have any idea what others are using for regression tests, but
> will
> you run them and see if they pass?
> Below is an excerpt from HISTORY.TXT showing changes since 4.2.3. I'd
> also
> like to include with this release a file that describes known bugs.
> According to Bugzilla, there are 32 unresolved bugs in the 4.2 version.
> Of these, only 7 have been assigned. The rest remain with status "New".
> I'm not trying to pick on anybody, but if we all acted a bit more quickly
> to change status to "Assigned" or "Unconfirmed", it would be a lot easier
> to enumerate the known bugs in mapserver. I have a suggestion on this in
> another email.
> cheers,
> Sean
> Version 4.2.4
> - Various fixes allowing unit tests to run leak free under valgrind on
> i686. Memory is now properly freed when exiting from common error
> states (bug 927).
> - Restored ability to render transparent (indexed or alpha) pixmap
> symbols
> on RGB map images, including annotation layers and embedded scalebars.
> This feature remains OFF by default for map layers and is enabled by
> specifying TRANSPARENCY ALPHA (bugs 926, 490).
> - New and improved Java mapscript build provided by
> unicoletti at prometeo.it,
> and examples contributed by Y.K. Choo (bug 876).
> - Fixed bug 863: Output MapContext parameters (SRS and DataURL) in the
> order
> required by the spec.
> - searchImageCache() in mapgd.c now checks all three style colors before
> using a cached brush image (bug 868).
> - Fixed bug 857: Fix msDecodeHTMLEntities to not skip characters after
> each
> decoding.
> - Fixed bug 834: SE_ROW_ID in SDE not initialized for unregistered SDE
> tables
> Sean Gillies
> sgillies at frii dot com
> http://users.frii.com/sgillies
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
