[Mapserver-dev] mapwms.c time support addition
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Tue Oct 12 12:01:25 EDT 2004
Assefa,
I noticed you added this when I checked out CVS -- yahoo!
I gave this a try, by adding "wms_timeextent" and "wms_timedefault" to
LAYER metadata in my mapfile.
So far so good.
When I issue
http://localhost/mswms?version=1.1.1&service=WMS&request=GetCapabilities
, one can see the Dimension and Extent elements, however the XML
document is no valid. This is what comes back, relative to Dimension
and Extent:
<Dimension name="time" units="ISO8601">
<Extent name="time" default="some_timedefault" multipleValues="1"
nearestValue="0">some_timeextent</Extent>
Issues:
1./ Dimension should be a closed, empty element, i.e.:
<Dimension name="time" units="ISO8601"/>
2./ in Extent, @multipleValues is not a part of the WMS 1.1.1 DTD.
Extent should look like:
Committing these two changes results in a valid WMS 1.1.1
GetCapabilities response. See below for DTD def summary:
Cheers
..Tom
http://schemas.opengis.net/wms/1.1.1/WMS_MS_Capabilities.dtd defines
Dimension and Extent as follows:
<!ELEMENT Dimension EMPTY >
<!ATTLIST Dimension
name CDATA #REQUIRED
units CDATA #REQUIRED
unitSymbol CDATA #IMPLIED>
<!-- The Extent element indicates what _values_ along a dimension are
valid. -->
<!ELEMENT Extent (#PCDATA) >
<!ATTLIST Extent
default CDATA #IMPLIED
nearestValue (0 | 1) "0">
