[Mapserver-dev] FCGI & Database Failure
Howard Butler hobu at iastate.edu
Tue Oct 19 16:56:25 EDT 2004
>there needs to be a test right after the connection is obtained from the
>pool of "is this connection any good?".
SDE does not have a method to answer this question directly.  You can see
in msSDECloseConnection I make a call to SE_connection_free_all_locks which
fakes one way of asking if the connection is good or not (no locks are
created if you are only selecting in SDE, but the function will complain if
the connection is no good).
Howard
