[Mapserver-dev] Header update
Frank Warmerdam
warmerdam at pobox.com
Thu Oct 21 09:14:53 EDT 2004
Folks,
OK, I have made a grueling pass through most of the main mapserver directory
code adding standardish headers that look somewhat like what is below.
A few notes:
o I relicensed all files under my own copyright to be held by the Regents
of U of M.
o I used "Author: Steve Lime and the MapServer team" when I wasn't immediately
aware of another primary author. If I have set the author in error in a
file you feel you authored, feel free to fix it.
o If a file already had decent headers, I mostly left things the same, except
for adding the MS_CVSID() macro.
o I didn't change the copyright message on any file that already had one. But
I used the standard U of M message for any file without a message, including
some I know to have been authored by folks outside U of M. If you authored a
file and want to hold the copyright personally (or corporately), just fix
it up ... but don't wait too long to do so.
o I ignored a few file - autogenerated ones and ones copied from other sources
and unlikely to be under maintenance.
o I tried to set meaningful "Purpose" messages for each file, but I obviously
don't know what every file is for, so some of them are lame or inaccurate.
Feel free to correct.
* Project: MapServer
* Purpose: High level msDrawMap() implementation and related functions.
* Author: Steve Lime and the MapServer team.
* Copyright (c) 1996-2004 Regents of the University of Minnesota.
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies of this Software or works derived from this Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
* OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
* $Log: mapdraw.c,v $
* Revision 1.76 2004/10/21 04:30:55 frank
* Added standardized headers. Added MS_CVSID().
#include <assert.h>
#include "map.h"
#include "maptime.h"
MS_CVSID("$Id: mapdraw.c,v 1.76 2004/10/21 04:30:55 frank Exp $")
Finally, I would like to note I got 85 CVS commits out of this effort. When
we all die, and the programmer gods count our CVS commits to see who gets
alpha geek bragging rights, I will have moved up a few places in the MapServer
pantheon this day :-) MapServer isn't as "small" as it used to be!
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
