[Mapserver-dev] configure script problems with multiple GD
Sean Gillies sgillies at frii.com
Mon Oct 25 13:45:42 EDT 2004
Users continue to report problems with the configure script
not picking up their own local installations of GD.  After
looking in configure.in, I'm not sure that GD_LIBDIR is
being properly set before we use AC_CHECK_LIB to look for
gdImageSetAntialias (test for GD version > 2.0.12), or that
adding -L$GD_LIBDIR will work to push the user-configured
GD location ahead of other system GD installations.
I'm also not experienced enough with autoconf to fix this
myself.  Could we set the right person to this task before
a final 4.4.0 release?
Not every user will have the option of removing every
conflicting GD from their system, or of modifying their
linker's system search order.
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
