[Mapserver-dev] include directive for mapfiles
Ed
Ed
Fri Oct 29 10:06:48 EDT 2004
Tom -
I think Paul's talking about the same preprocessor approach I am. It is not a "runtime" approach in that it requires the user to run a process to interpret static information only once, rather than repeating the same static process for every map view <g>. A runtime approach is much more valuable if it can be controlled by the use of runtime parameters, not static data.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: mapserver-dev-admin at lists.gis.umn.edu [mailto:mapserver-dev-admin at lists.gis.umn.edu] On Behalf Of Kralidis,Tom [Burlington]
Sent: Friday, October 29, 2004 9:58 AM
To: Paul Ramsey
Cc: mapserver-dev at lists.gis.umn.edu
Subject: RE: [Mapserver-dev] include directive for mapfiles
Paul,
No I haven't. What is the approach? And this sounds like making mods to the source code? If yes, I was looking for a canned, runtime solution.
..Tom
> From: Paul Ramsey [mailto:pramsey at refractions.net]
> Sent: Friday, 29 October, 2004 09:56
> To: Kralidis,Tom [Burlington]
> Subject: Re: [Mapserver-dev] include directive for mapfiles
> Tom,
> Have you tried and given up on using cpp as a means of managing map
> files? I recently used a cpp/make combination for a larger project,
> and I thought it worked pretty OK.
> Paul
> On 29-Oct-04, at 6:44 AM, Kralidis,Tom [Burlington] wrote:
> > During a spirited conversation with Frank and Dave last
> night, I was
> > encouraged to send a post w.r.t. this subject, so here goes:
> > For those of us running MapServer with multiple datasets,
> definitions,
> > etc., it would be nice to be able to 'compartmentalize'
> mapfile chunks
> > which other mapfiles can refer to.
> > I'd be interested in hearing others' thoughts of defining a new
> > mapfile object called 'INCLUDE', which does just that, include
> > contents of another mapfile, i.e.:
> > INCLUDE 'roads.map'
> > Comments?
> > Thanks
> > ..Tom
> > Mapserver-dev mailing list
> > Mapserver-dev at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
