[Mapserver-dev] OWS metadata and LegendURL clarification
Kralidis,Tom [Burlington] Tom.Kralidis at ec.gc.ca
Fri Oct 29 10:18:26 EDT 2004
> -----Original Message-----
> From: Paul Spencer [mailto:pagameba at magma.ca]
> Sent: Friday, 29 October, 2004 10:12
> To: Kralidis,Tom [Burlington]
> Cc: mapserver-dev at lists.gis.umn.edu
> Subject: Re: [Mapserver-dev] OWS metadata and LegendURL clarification
> Tom ... comment below ...
> Kralidis,Tom [Burlington] wrote:
> > Hi,
> > First off, I'd like to thank Julien and Assefa for their work in
> > implementing msOWSPrintURLType() (bug 944)into CVS and
> LegendURL (bug
> > 1001).  This will enable richer output for OGC metadata in
> > Capabilities, as well as streamlining the way URLs are formatted.
> > This will be a big benefit for the catalogs and registries
> out there
> > who harvest OGC Web Services for discovery.
> > As a result, mapfiles can now define:
> > "wms_dataurl_format"
> > "wms_dataurl_type"
> > "wms_dataurl_href"
> > "wms_metadataurl_format"
> > "wms_metadataurl_type"
> > "wms_metadataurl_href"
> > "wfs_metadataurl_format"
> > "wfs_metadataurl_type"
> > "wfs_metadataurl_href"
> > Question:
> > will the generic ows_* directives be implemented for WMS
> and WFS, as
> > they were for WCS, in time for 4.4.0?
> > For Legends (bug 262, which was solved by bug 944):
> > wms_style    =>  name of the style
> > wms_style_<style's_name>_legendurl_href
> > wms_style_<style's_name>_legendurl_format
> > wms_style_<style's_name>_legendurl_width
> > wms_style_<style's_name>_legendurl_height
> > Question:
> > The issue I have with this is that someone has to explicitly define
> > this in the mapfile.  AFAIK, MapServer doesn't support
> multiple styles
> > in WMS for layers, so we always default to one style.
> this is implemented to support *other* wms servers that do support
> multiple styles.  When parsing contexts or capabilities, we
> need a place
> to store the styles supported by the remote server and this was the
> mechanism chosen to do this.  This allows mapscript applications to
> present a choice of styles to the user and to allow them to change
> between styles.  MapServer (as a WMS client) will append the
> appropriate
> STYLE= to GetMap requests ... the other information is there to allow
> mapscript applications to generate some sort of reasonable legend
> graphic if possible since legends are not supported through the WMS
> server yet (at least not directly).
> > IMHO, the only directives a user should be able to configure are:
> > "wms_legendurl_href"
> > "wms_legendurl_width"
> > "wms_legendurl_height"
> > (note the change to "wms_legendurl_*" from
> > "wms_style_<style's_name>_legendurl_*)
> > If and only if they define a static image for the href.
> Else, if they
> > don't define anything a LegendURL should be returned in
> Capabilities.
> > This is partly addressed in bug 1001.
> > Comments?  I hope this made sense.
> I think your suggestion would break all my code :>
I see your point from the client side of things.  However, from the WMS
Server side, I see this could be a potential burden i.e. creating
'wms_style*' info when all this could be generated on the fly by the
server (i.e. with GetLegendGraphic and default styles).
> > ..Tom
> > Mapserver-dev mailing list
> > Mapserver-dev at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
> |Paul Spencer                           pspencer at dmsolutions.ca   |
> |Applications & Software Development                              |
> |DM Solutions Group Inc                 http://www.dmsolutions.ca/|
