[Mapserver-dev] OWS metadata and LegendURL clarification
Yewondwossen Assefa assefa at dmsolutions.ca
Fri Oct 29 10:33:32 EDT 2004
We could also decide that if the wms_style_* is not defined in the map
file, we could still generate a LegendURL (pointing to a
GetLegendgGraphic with defeault width and heigh taken from the legend
element if available ). This syle returned would be "default" as
suggested in bug 1001.
The only think that I do not like is that we are telling the user that a
style named default is available which is not really true. If we do that
we should also support request with STYLE=default to be compatible.
One last thing, I think we shoudl either continue this in bug 1001 or
open a new one.
Kralidis,Tom [Burlington] wrote:
>>-----Original Message-----
>>From: Paul Spencer [mailto:pagameba at magma.ca]
>>Sent: Friday, 29 October, 2004 10:12
>>To: Kralidis,Tom [Burlington]
>>Cc: mapserver-dev at lists.gis.umn.edu
>>Subject: Re: [Mapserver-dev] OWS metadata and LegendURL clarification
>>Tom ... comment below ...
>>>Hi,
>>>First off, I'd like to thank Julien and Assefa for their work in
>>>implementing msOWSPrintURLType() (bug 944)into CVS and
>>LegendURL (bug
>>>1001).  This will enable richer output for OGC metadata in
>>>Capabilities, as well as streamlining the way URLs are formatted.
>>>This will be a big benefit for the catalogs and registries
>>out there
>>>who harvest OGC Web Services for discovery.
>>>As a result, mapfiles can now define:
>>>"wms_dataurl_format"
>>>"wms_dataurl_type"
>>>"wms_dataurl_href"
>>>"wms_metadataurl_format"
>>>"wms_metadataurl_type"
>>>"wms_metadataurl_href"
>>>"wfs_metadataurl_format"
>>>"wfs_metadataurl_type"
>>>"wfs_metadataurl_href"
>>>Question:
>>>will the generic ows_* directives be implemented for WMS
>>and WFS, as
>>>they were for WCS, in time for 4.4.0?
>>>For Legends (bug 262, which was solved by bug 944):
>>>wms_style    =>  name of the style
>>>wms_style_<style's_name>_legendurl_href
>>>wms_style_<style's_name>_legendurl_format
>>>wms_style_<style's_name>_legendurl_width
>>>wms_style_<style's_name>_legendurl_height
>>>Question:
>>>The issue I have with this is that someone has to explicitly define
>>>this in the mapfile.  AFAIK, MapServer doesn't support
>>multiple styles
>>>in WMS for layers, so we always default to one style.
>>this is implemented to support *other* wms servers that do support
>>multiple styles.  When parsing contexts or capabilities, we
>>need a place
>>to store the styles supported by the remote server and this was the
>>mechanism chosen to do this.  This allows mapscript applications to
>>present a choice of styles to the user and to allow them to change
>>between styles.  MapServer (as a WMS client) will append the
>>appropriate
>>STYLE= to GetMap requests ... the other information is there to allow
>>mapscript applications to generate some sort of reasonable legend
>>graphic if possible since legends are not supported through the WMS
>>server yet (at least not directly).
>>>IMHO, the only directives a user should be able to configure are:
>>>"wms_legendurl_href"
>>>"wms_legendurl_width"
>>>"wms_legendurl_height"
>>>(note the change to "wms_legendurl_*" from
>>>"wms_style_<style's_name>_legendurl_*)
>>>If and only if they define a static image for the href.
>>Else, if they
>>>don't define anything a LegendURL should be returned in
>>Capabilities.
>>>This is partly addressed in bug 1001.
>>>Comments?  I hope this made sense.
>>I think your suggestion would break all my code :>
> I see your point from the client side of things.  However, from the WMS
> Server side, I see this could be a potential burden i.e. creating
> 'wms_style*' info when all this could be generated on the fly by the
> server (i.e. with GetLegendGraphic and default styles).
>>>..Tom
>>>_______________________________________________
>>>Mapserver-dev mailing list
>>>Mapserver-dev at lists.gis.umn.edu
>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
>>|Paul Spencer                           pspencer at dmsolutions.ca   |
>>|Applications & Software Development                              |
>>|DM Solutions Group Inc                 http://www.dmsolutions.ca/|
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
