[Mapserver-dev] OWS metadata and LegendURL clarification
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Fri Oct 29 10:23:51 EDT 2004
> -----Original Message-----
> From: Julien-Samuel Lacroix [mailto:jlacroix at dmsolutions.ca]
> Sent: Friday, 29 October, 2004 10:20
> To: Kralidis,Tom [Burlington]
> Cc: mapserver-dev at lists.gis.umn.edu
> Subject: Re: [Mapserver-dev] OWS metadata and LegendURL clarification
> Comment in-line.
> Kralidis,Tom [Burlington] wrote:
> > Hi,
> > First off, I'd like to thank Julien and Assefa for their work in
> > implementing msOWSPrintURLType() (bug 944)into CVS and
> LegendURL (bug
> > 1001). This will enable richer output for OGC metadata in
> > Capabilities, as well as streamlining the way URLs are formatted.
> > This will be a big benefit for the catalogs and registries
> out there
> > who harvest OGC Web Services for discovery.
> :) Thank to you for the feedback!
> > As a result, mapfiles can now define:
> > "wms_dataurl_format"
> > "wms_dataurl_type"
> > "wms_dataurl_href"
> > "wms_metadataurl_format"
> > "wms_metadataurl_type"
> > "wms_metadataurl_href"
> > "wfs_metadataurl_format"
> > "wfs_metadataurl_type"
> > "wfs_metadataurl_href"
> > Question:
> > will the generic ows_* directives be implemented for WMS
> and WFS, as
> > they were for WCS, in time for 4.4.0?
> I don't know if it was plan for the rest of the WMS/WFS code, but all
> those metadata are already available in the ows_*_* form. Also, the
> switch to support wms/wfs_* and ows_* in WMS/WFS code should
> be fairly
> easy I think. I will let Daniel comment.
> > For Legends (bug 262, which was solved by bug 944):
> > wms_style => name of the style
> > wms_style_<style's_name>_legendurl_href
> > wms_style_<style's_name>_legendurl_format
> > wms_style_<style's_name>_legendurl_width
> > wms_style_<style's_name>_legendurl_height
> > Question:
> > The issue I have with this is that someone has to explicitly define
> > this in the mapfile. AFAIK, MapServer doesn't support
> multiple styles
> > in WMS for layers, so we always default to one style.
> > IMHO, the only directives a user should be able to configure are:
> > "wms_legendurl_href"
> > "wms_legendurl_width"
> > "wms_legendurl_height"
> > (note the change to "wms_legendurl_*" from
> > "wms_style_<style's_name>_legendurl_*)
> > If and only if they define a static image for the href.
> Else, if they
> > don't define anything a LegendURL should be returned in
> Capabilities.
> > This is partly addressed in bug 1001.
> > Comments? I hope this made sense.
> This was made like that for consistency with MapContext. In
> MapContext,
> we set wms_style_<style's_name>_legendurl_* because we can have more
> than one style. Do the WMS spec allow to have more than one
> style? If so
> we may want to support multiple styles and then this approach
> will make
> sense in WMS. But I also agree that it's a pretty big name for a
> metadata and that it reduce it's useability. Maybe we can
> support both
> format. use wms_style_blabla_... when we will have the wms_style
> metadata and use wms_legendurl_* when we won't have a style defined.
> However this may lead to confusion. What others think?
I agree this may be confusing. Perhaps I should simplify my
question/request:
In a WMS Server scenario, I'd like to be able to *not* specify any
"wms_style" information, and still have the WMS Capabilities the
LegendURL with the GetLegendGraphic request dynamically generated in the
xlink:href.
..Tom
> > ..Tom
> Thanks
> Julien
> Julien-Samuel Lacroix jlacroix at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
