[Mapserver-dev] OWS metadata and LegendURL clarification
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Fri Oct 29 10:41:44 EDT 2004
> -----Original Message-----
> From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
> Sent: Friday, 29 October, 2004 10:34
> To: Kralidis,Tom [Burlington]
> Cc: pspencer at dmsolutions.ca; mapserver-dev at lists.gis.umn.edu
> Subject: Re: [Mapserver-dev] OWS metadata and LegendURL clarification
> We could also decide that if the wms_style_* is not defined
> in the map
> file, we could still generate a LegendURL (pointing to a
> GetLegendgGraphic with defeault width and heigh taken from the legend
> element if available ). This syle returned would be "default" as
> suggested in bug 1001.
> The only think that I do not like is that we are telling the
> user that a
> style named default is available which is not really true. If
> we do that
> we should also support request with STYLE=default to be compatible.
> One last thing, I think we shoudl either continue this in bug 1001 or
> open a new one.
The comment #4 of bug 1001 discussed the LegendURL issue.
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1001#c4
> >>From: Paul Spencer [mailto:pagameba at magma.ca]
> >>Sent: Friday, 29 October, 2004 10:12
> >>Cc: mapserver-dev at lists.gis.umn.edu
> clarification
> >>Tom ... comment below ...
> >>>Hi,
> >>>First off, I'd like to thank Julien and Assefa for their work in
> >>>implementing msOWSPrintURLType() (bug 944)into CVS and
> >>LegendURL (bug
> >>>1001). This will enable richer output for OGC metadata in
> >>>Capabilities, as well as streamlining the way URLs are formatted.
> >>>This will be a big benefit for the catalogs and registries
> >>out there
> >>>who harvest OGC Web Services for discovery.
> >>>As a result, mapfiles can now define:
> >>>"wms_dataurl_format"
> >>>"wms_dataurl_type"
> >>>"wms_dataurl_href"
> >>>"wms_metadataurl_format"
> >>>"wms_metadataurl_type"
> >>>"wms_metadataurl_href"
> >>>"wfs_metadataurl_format"
> >>>"wfs_metadataurl_type"
> >>>"wfs_metadataurl_href"
> >>>Question:
> >>>will the generic ows_* directives be implemented for WMS
> >>and WFS, as
> >>>they were for WCS, in time for 4.4.0?
> >>>For Legends (bug 262, which was solved by bug 944):
> >>>wms_style => name of the style
> >>>wms_style_<style's_name>_legendurl_href
> >>>wms_style_<style's_name>_legendurl_format
> >>>wms_style_<style's_name>_legendurl_width
> >>>wms_style_<style's_name>_legendurl_height
> >>>Question:
> >>>The issue I have with this is that someone has to explicitly define
> >>>this in the mapfile. AFAIK, MapServer doesn't support
> >>multiple styles
> >>>in WMS for layers, so we always default to one style.
> >>this is implemented to support *other* wms servers that do support
> >>multiple styles. When parsing contexts or capabilities, we
> >>need a place
> >>to store the styles supported by the remote server and this was the
> >>mechanism chosen to do this. This allows mapscript applications to
> >>present a choice of styles to the user and to allow them to change
> >>between styles. MapServer (as a WMS client) will append the
> >>appropriate
> >>STYLE= to GetMap requests ... the other information is
> there to allow
> >>mapscript applications to generate some sort of reasonable legend
> >>graphic if possible since legends are not supported through the WMS
> >>server yet (at least not directly).
> >>>IMHO, the only directives a user should be able to configure are:
> >>>"wms_legendurl_href"
> >>>"wms_legendurl_width"
> >>>"wms_legendurl_height"
> >>>(note the change to "wms_legendurl_*" from
> >>>"wms_style_<style's_name>_legendurl_*)
> >>>If and only if they define a static image for the href.
> >>Else, if they
> >>>don't define anything a LegendURL should be returned in
> >>Capabilities.
> >>>This is partly addressed in bug 1001.
> >>>Comments? I hope this made sense.
> >>I think your suggestion would break all my code :>
> > I see your point from the client side of things. However, from the
> > WMS Server side, I see this could be a potential burden
> i.e. creating
> > 'wms_style*' info when all this could be generated on the
> fly by the
> > server (i.e. with GetLegendGraphic and default styles).
> >>>..Tom
> >>>_______________________________________________
> >>>Mapserver-dev mailing list
> >>>Mapserver-dev at lists.gis.umn.edu
> >>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
> >>|Paul Spencer pspencer at dmsolutions.ca |
> >>|Applications & Software Development |
> >>|DM Solutions Group Inc http://www.dmsolutions.ca/|
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
