[Mapserver-dev] hierarchical map files
Titus von der Malsburg malsburg at cl.uni-heidelberg.de
Fri Sep 3 05:31:07 EDT 2004
On Tue, Aug 31, 2004 at 01:03:03AM +0200, Carlo A. Bertelli wrote:
> definitely, when you have a lot of layers, MS maps are not easily
> manageable between several applications.
Hi Carlo,
I use the C preprocessor to manage very large modular mapfiles and it works
quite well.  It gives you at least two additional tools:
	Includes: I use them just as you described it
	Variables: for things like
		SHAPEPATH MYSHAPEPATH
		MINSCALE MYSCALE_MIN
		MAXSCALE MYSCALE_MAX
	or for things like
		#ifdef DEBUG
  		LAYER
      		NAME "graticule"
		#endif
If you embed this in a configure/make-setup it is a very convenient
solution.
	Titus
