[Mapserver-dev] Layer TYPE TILEINDEX and PostGIS
Daniel Morissette dmorissette at dmsolutions.ca
Fri Sep 3 14:48:01 EDT 2004
Stephan M. wrote:
> Hi Developers,
> Really nice tool this mapserser!!!
> Nevertheless I found a small bug: In 'mappostgis.c' in the function
> 'msPOSTGISLayerGetShapeRandom()' in the switch statement the case for
> the layer type MS_LAYER_TILEINDEX is missing. I copied everything from
> the MS_LAYER_POLYGON case and everything works.
I would suggest that you file a bug in the MapServer bugsilla with your
proposed patch so that the PostGIS guys can review and commit it.
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
