[Mapserver-dev] Modularizing mapserver
Sean Gillies sgillies at frii.com
Thu Sep 16 13:19:56 EDT 2004
On Sep 16, 2004, at 10:54 AM, Daniel Morissette wrote:
> Sean Gillies wrote:
>> Currently, every file is lumped under mapserver/ and every file
>> is a build target that may or may not have an #ifdef bracketing
>> its code.  Wouldn't it be better to handle conditional compilation
>> of packages (such as PDF, iamgemap, SWF) in the makefile than in
>> the source?
> Better? It depends on who you ask. Steve's approach to dealing with
> optional components in MapServer has been to always compile every
> file, and use #ifdefs to disable the code and provide stub functions
> for disabled components. That didn't seem natural for me at first
> either, but I got used to it, and I don't see any problem with that
> approach, so as usual I would say:"if it ain't broken don't touch
> it"... and vote against that change... unless someone can demonstrate
> that there are real issues with this approach of course.
> Daniel
Yes, the current approach works.  I was suggesting that a modular
approach
would be more sustainable in the long run, that's all.
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
