[Mapserver-dev] virtualising attribute data
Daniel Morissette
dmorissette at dmsolutions.ca
Wed Sep 22 10:22:18 EDT 2004
Attila Csipa wrote:
> I was thinking about the possibilities of virtualising attribute data for my
> needs, meaning that for example a layer that has spatial data in a shapefile
> has the attribute data in plain mysql (this is how it works in my prototype
> test and happens to be the most requested feature that I got). Note that this
> is _not_ the same as doing a join and not like using virtualspatialogr.
Have you thought about using an OGR SQL join? I think that would do
exactly what you need. Look for JOIN in http://ogr.maptools.org/ogr_sql.html
I don't think OGR supports MySQL directly (maybe it does?), but you
could connect to MySQL or most other databases through OGR's ODBC driver.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
