[Mapserver-dev] virtualising attribute data
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Sep 22 11:18:23 EDT 2004
Daniel Morissette wrote:
> Attila Csipa wrote:
>> I was thinking about the possibilities of virtualising attribute data
>> for my needs, meaning that for example a layer that has spatial data
>> in a shapefile has the attribute data in plain mysql (this is how it
>> works in my prototype test and happens to be the most requested
>> feature that I got). Note that this is _not_ the same as doing a join
>> and not like using virtualspatialogr.
> Have you thought about using an OGR SQL join? I think that would do
> exactly what you need. Look for JOIN in
> http://ogr.maptools.org/ogr_sql.html
> I don't think OGR supports MySQL directly (maybe it does?), but you
> could connect to MySQL or most other databases through OGR's ODBC driver.
I for one would like to see a virtualised attribute capability in
mapserver because:
1) setting up ODBC drivers are a real pain on Linux
2) currently joins are not supported on rendering
3) I have 100 GB of Census Summary file data in MySQL and would like to
render thematic maps of Tiger data in shapefiles
4) The prospect of learning PostGIS/postgre and moving all the Census
data and all the Tiger data to PostGIS just seems like an overwhelming
and time consuming task given all the other things I would like to be doing.
OK, so I'm probably not in the main stream, but I think that this would
be a good feature that other would use if it is available.
-Steve W.
http://imaptools.com
