[Mapserver-dev] FastCGI and MapServer 4.4
Frank Warmerdam
warmerdam at pobox.com
Mon Sep 27 22:27:03 EDT 2004
Fernando S. wrote:
> Smith,
> Thank's for the code. This function I already rewrited/change in my
> local tree, I extended it but now I'm testing because occurred some
> problems when the user don't have a defined SRID in database and want's
> to use projection. SRID can be a requirement when use projection? I'm
> thinking about this.....
> If my last version pass in my tests I will commit in cvs. Do you have
> more hint for the code?
> Frank, sorry for may last e-mail, I forgot to explain I'm already
> following the colloquy, but I had not undestood before you explain.
> Thank's. Now I'm reading the wiki to understant more......
> About the maporaclespatial code, more hints?
Fernando,
I will provide more info on the connection pooling changes once I have that
code implemented and committed. There is some question of course whether
the connection pooling changes should be address in 4.3/4.4 or 4.5/4.6.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
