GIF Raster Data Problem
Daniel Morissette
dmorissette at DMSOLUTIONS.CA
Wed Apr 27 09:23:57 EDT 2005
Akio,
This is the -dev list, which is reserved for discussion relating to the
development of the software.
Questions relating to the use of the software should be sent to the
mapserver-users list, where there are hundreds of users willing to share
their knowledge.
Hint: your problem is most likely that you are missing a world file for
your .GIF image. The raster howto in the mapserver docs page will tell
you all you need to know about rasters.
Daniel
Akio Neuchi wrote:
> Hello to all,
> I am still quite new working with MapServer, and this is my first time to
> process a Raster Image, especially with GIF files. (Besides, my Vector
> Layers work fine on MAP file).
> I tried the following definition, and the result was null, just an OFFSITE
> color.
> Am I doing something basically wrong? Do I need to set GDAL on ./config for
> accessing simple GIF files?
> Please send me your advice. Thanks in advance for your help.
> Akio Neuchi
> MAP
> NAME rastest
> STATUS ON
> SIZE 600 700
> EXTENT 121.938889 23.442222 149.500001 46.466666
> UNITS dd
> SHAPEPATH "data"
> FONTSET "./fonts/fonts.lst"
> #SYMBOLSET "/var/www/html/zoom2it_mapserver/map_symbols/symbols.sym"
> IMAGECOLOR 225 240 200
> DEBUG ON
> IMAGETYPE GIF
> #IMAGETYPE PNG
> #IMAGETYPE JPEG
> #IMAGEQUALITY 400
> WEB
> EMPTY "/gistest/empty.html"
> HEADER decide_route_header.html
> TEMPLATE decide_route.html
> FOOTER decide_route_footer.html
> MINSCALE 0
> MAXSCALE 1500000000
> IMAGEPATH
> /var/opt/SUNWappserver7/domains/domain1/server1/docroot/gistest/tmp
> IMAGEURL /gistest/tmp
> LOG
> /var/opt/SUNWappserver7/domains/domain1/server1/docroot/gistest/rastest.log
> # TEMPLATE "decide_route.html"
> METADATA
> WMS_TITLE "Raster Map Display Demo"
> WMS_ABSTRACT "Created by TCI"
> WMS_ACCESSCONSTRAINTS none
> END
> END
> QUERYMAP
> SIZE 200 200
> STATUS ON
> STYLE HILITE
> COLOR 255 0 0
> END
> OUTPUTFORMAT
> NAME gif
> MIMETYPE "image/gif"
> DRIVER "GD/GIF"
> EXTENSION "gif"
> IMAGEMODE PC256
> # TRANSPARENT FALSE
> # FORMATOPTION "INTERLACE=OFF"
> END
> OUTPUTFORMAT
> NAME png
> MIMETYPE "image/png"
> DRIVER "GD/PNG"
> EXTENSION "png"
> IMAGEMODE PC256
> # TRANSPARENT FALSE
> END
> OUTPUTFORMAT
> NAME jpeg
> MIMETYPE "image/jpeg"
> DRIVER "GD/JPEG"
> EXTENSION "jpg"
> IMAGEMODE RGB
> # TRANSPARENT FALSE
> END
> # RASTER Layer
> LAYER
> NAME "RAS365313"
> GROUP "B_RASTER"
> TYPE RASTER
> STATUS ON
> # STATUS DEFAULT
> # TOLERANCE 5
> # TOLERANCEUNITS PIXELS
> # OFFSITE 0 0 0
> OFFSITE 169 109 154
> # DATA "MS12000DEF365313.png"
> # DATA "MS12000DEF365313.jpeg"
> CLASS
> COLOR 225 200 100
> END
> DUMP TRUE
> DEBUG ON
> END
> END # Map File
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
