DWithin using a polygon on MapInfo tab file(OGR)
Bart van den Eijnden
bartvde at XS4ALL.NL
Wed Apr 27 14:50:32 EDT 2005
I tested just now using 4.4.2 sources updated with the latest mapquery.c.
Works like a charm.
Thanks Assefa!
Best regards,
Bart
On Wed, 27 Apr 2005 13:03:19 -0400, Yewondwossen Assefa
<assefa at DMSOLUTIONS.CA> wrote:
> Bart,
> I have updated bug 1335 and commited the fix. Is it possible to test
> with latest CVS version. I don't think there is going to be a 4.4.3
> version since the 4.6 is about to come so I did not port the fix in that
> branch.
> Later,
> Bart van den Eijnden wrote:
>> Hi Assefa,
>> I am now even getting crashes using shapefiles as a datasource.
>> Will add that to the bugreport/testcase.
>> Thanks for looking into this.
>> Best regards,
>> Bart
>> Syncera-ITSolutions
>> Postbus 270
>> 2600 AG DELFT
>> tel.nr.: 015-7512436
>> email: BEN at Syncera-ITSolutions.nl
>>>>> Yewondwossen Assefa <assefa at dmsolutions.ca> 04/27/05 06:01pm >>>
>> Looking into this ...
>>> Hi list,
>>> I was trying to perform a DWithin request (Mapserver WFS) on a Mapinfo
>>> layer (OGR), but Mapserver crashes.
>>> I then tried converting the Mapinfo file to shapefile and everything
>>> worked fine, so this is probably a bug somewhere.
>>> I have opened up the following bug report with a testcase/attachment:
>>> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1335
>>> Maybe somebody knows whether or not this has been fixed in CVS?
>>> Best regards,
>>> Bart
>>> Syncera-ITSolutions
>>> Postbus 270
>>> 2600 AG DELFT
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
