fast-cgi
Ed McNierney ed at TOPOZONE.COM
Fri Apr 29 07:10:28 EDT 2005
Huub -
And what would that bug be?  Caching is a good thing - since there are
no other demands on memory, and fast-cgi processes are SUPPOSED to stay
resident, how can you tell that anything's wrong?
What would you EXPECT the memory usage to be?  Since RAM is good for
caching, it's usually GOOD for programs to use as much available RAM as
they can take advantage of, as long as they're not competing with other
applications.
        - Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
-----Original Message-----
From: UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU]
On Behalf Of Huub
Sent: Friday, April 29, 2005 6:26 AM
To: MAPSERVER-DEV at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-DEV] fast-cgi
Hi List,
(new thread,the same name)
Well,
this morning i could see that memoryusage was over 700Mb the 8
mapserv.fcgi processes were gone.
After stopping apache the memoryusage of the server dropped to 414Mb
Then i continued to use (the approved)
http://213.197.234.107/testfcgi.htm (now timing results)
after lets say 50 zoomins/outs (50 for 4.5 cgi and 50 for 4.6beta fcgi)
10.05h i see 3 mapserv.fcgi in the processlist memory is 873Mb 10.15h 3
mapserv.fcgi (154672Kb,156128Lb,20000 Kb): 740Mb 10.45h 3 mapserv.fcgi
(154672Kb,156128Lb,20000 Kb): 740Mb (now i closed the browser) 11.15h 3
mapserv.fcgi (154672Kb,156128Lb,20000 Kb): 740Mb Stopped Apache.
mapserv.fcgi gone, Memoryusage dropped to 414Mb
am i missing something, or should i file a bug
httpd.conf fastcgi settings
LoadModule fastcgi_module modules/mod_fastcgi.dll AddHandler
fastcgi-script fcg fcgi fpl FastCgiConfig -idle-timeout 300
-killInterval 500 -initial-env PROJ_LIB -initial-env PATH -initial-env
TNS_ADMIN SetEnv TNS_ADMIN
"c:/oracle/product/10.1.0/Client_1/NETWORK/ADMIN"
SetEnv PATH "C:/Oracle/product/10.1.0/Client_1/BIN"
Regards, Huub
